Yes, Tune-Up day will be at my place. The address is 686 Prospect, Berea, 44017, which is also State Route 237. It's right near the turnpike crossover, the turnpike building, about 1.5 miles south of Berea downtown, and 2.5 miles north of Rt 82 Strongsville.
BUT- DON'T go to the front building which is marked 686, they won't know what you're there for. Turn down Greenfield Court, drive 100 yards, and turn right through the gate. You won't miss my building.
Zoom out:
Zoom in:
See you there!
2017 - Tune Up Day - May 13th
Re: 2017 - Tune Up Day - May 13th
I won't be bringing any projects so I will be around to lend a hand as always .
my bus could use a little light sanding and a little fresh paint,
Never asked for a motorcycle...
Mopar's Rock...
Mopar's Rock...
A gallon of Sears Weatherbeater and a roller? We can do that!
Hello this is ragman73 I would love to attend the date and would appreciate it if somebody can give me a hand with my brake light issue west side Dan told me it was the master cylinder that it only has one sensor and it needs two sensors and the one I have is the incorrect and I think he has one that has two sensors on it And I like to see if we can install it thank you P.S it's a 1970 bus
One love
Fernando, whether you have 1 or 2 brake lite switches on your mstr cyl. will not effect brake lites. Most likely the brake lite switch or a wiring issue. Mik at Euclid Foreign Motors should have the switch(s). I think he also owns a 70 bus.
Ok that's sounds awesome one thing though he switched the plugs and I have stop lites now but no turn signals in the back.The signals in the front work and the bulbs are good in the back
One love
Wiring issue, wrong taillights, or turn signal switch issue, depending. Bring it up, we might be able to do something.
