914
914
In the process of aquiring a 73 914 with a two liter and 916 suspension.so far I have gotten the motor,cleaned the crap out of it,cleand the exchangers up,dismantled the long block ,I don't plan on spliting the case.I broke the heads down everythings good except exhaust vavles .its a low milage engine and looks as ifthe vavles on the one side wernt properly adjusted and peened the tops of the stems up.the guides are all in good shape .bill got me a great deal on valves and lifters witch just arived .the carbs are courtesy of a friend of mine and need to be claened and rebuilt but I have a set of fdelortos that come with the car also....
That's it for now
That's it for now
- Attachments
vanagons
mopeds
vanagons
mopeds
Re: 914
If anyone can't get deals on clutches I would apreciate it ,this ones my cost about
350
vanagons
mopeds
vanagons
mopeds
Re: 914
Really don't want to risk running the maybe clutch setup,the trans is closer to a 911 even if the engine is a type four .
- Attachments
vanagons
mopeds
vanagons
mopeds
Re: 914
Any pics of the car? I keep on hearing about but don't think I've seen it before
Re: 914
Plan on picking it up this month ."hopefully"
vanagons
mopeds
vanagons
mopeds
Re: 914
Currrent update ,heads are apart and new valves are lapped in ypon futher ivestigation I found the exhaust guides need replaced .so at my buddys shop I popped them out using a intresting way only can be used for removing.he had a special acessory for his air hammer that fit the guides and slowy pushed them out a real life saver ,I have new stainless vavles that I am putting in so. All I need is the guides and these babies are all finishd up.more pics soon
vanagons
mopeds
vanagons
mopeds
Re: 914
Great project. Had one of those a year or so back. Got it running then sold it. Scared the crap out of me.
1986 Westy
1974 Panel
1974 Panel
Re: 914
Why did it scare the crap out of you
vanagons
mopeds
vanagons
mopeds
Re: 914
lurch wrote:Why did it scare the crap out of you
Probably broke in half when he removed the targa top.
