Craig's 68 Panel
- CraigOnTheBoat
Craig's 68 Panel
Installing new Turn Signal Switch,Ignition Switch, Base Plastic Collar and Horn.
- CraigOnTheBoat
Re: 68 Panel
It's been awhile since any updates on the panel. The frail tired engine that was in it barely made it back home from tune up day.
New engine Single Port 1600
Re: 68 Panel
I run that engine in my Single Cab and am very happy with it.CraigOnTheBoat wrote:It's been awhile since any updates on the panel. The frail tired engine that was in it barely made it back home from tune up day.
- CraigOnTheBoat
Re: 68 Panel
I was in need of the lock assembly which was completely missing. just hanging out was the ignition switch which worked fine, but with a screwdriver. I have the steering lock and new switch , just haven't put it in yet.
- CraigOnTheBoat
Re: Craig's 68 Panel
Putting it to work this week tearing down a big deck behind my house
slayer
What carb are you running on that 1600 sp?
- CraigOnTheBoat
Its a 1600 SP , I think its a 30-PICT-2? Id have to take a look.
- CraigOnTheBoat
Scaled in at the landfill Saturday hauling
1700 lbs. 1st Trip - 1860 lbs 2nd Trip
