Craig's 68 Panel
Craig's 68 Panel
Installing new Turn Signal Switch,Ignition Switch, Base Plastic Collar and Horn.
Randy
Re: 68 Panel
Post by Randy »
Good buy, Craig. I was looking awfully hard at that bus.
Randy
1986 Westy
1974 Panel
Re: 68 Panel
It's been awhile since any updates on the panel. The frail tired engine that was in it barely made it back home from tune up day.
New engine Single Port 1600
Re: 68 Panel
CraigOnTheBoat wrote:It's been awhile since any updates on the panel. The frail tired engine that was in it barely made it back home from tune up day.
I run that engine in my Single Cab and am very happy with it. :D
Re: 68 Panel
I was in need of the lock assembly which was completely missing. just hanging out was the ignition switch which worked fine, but with a screwdriver. I have the steering lock and new switch , just haven't put it in yet.
Re: Craig's 68 Panel
Putting it to work this week tearing down a big deck behind my house
slayer
Post by slayer »
What carb are you running on that 1600 sp?
Its a 1600 SP , I think its a 30-PICT-2? Id have to take a look.
Scaled in at the landfill Saturday hauling
1700 lbs. 1st Trip - 1860 lbs 2nd Trip
