I need a machinist
I need a machinist
eny body know someone who can line bore and thrust cut a case,crank balancing?????????
Re: I need a machinist
Jim's custom VW in Columbiana for the case work. 800 621 3503.
CB performance for the crank. http://www.cbperformance.com/ProductDet ... tCode=1105
This is cheaper than crank grinding AND it's counterwieghted and balanced AND standard bearing surfaces.
Although Jim should be able to set you up with a similar crank.
Also check with RIS for the case work http://rismachine.tumblr.com/
He is a member of this forum.
