1961 Microbus
Re: 1961 Microbus
You're painting everything to isn't moving! Cool :o :D
Re: 1961 Microbus
Plug wires, cap, condenser, points, rotor, and some hoses and this part is done.
Re: 1961 Microbus
Looks good!
Late FI case, so electric FP? Or gravity feed? :P
Check your TDC with a piston stop tool, the aluminum pulleys I've checked were nowhere near accurate, not even close.......
Re: 1961 Microbus
Dual Port wrote:Looks good!
Good tip.
Next arts and crafts project is a run stand. Anyone have a junk trans or bell housing?
Re: 1961 Microbus
I have trannies but none I want to cut up. Don't make a run stand, it takes up too much real estate while being stored. A chunk of bell for a run adapter is all you need, I cut this with a Sawzall:
Get a 2 gallon outboard motor fuel tank and a battery and you're in business.
Re: 1961 Microbus
Still at it
1
Started with this piece of bent metal screwed to hinge
2
Missing piece of og metal
3
New piece of 22g sheet spotted to 18g spreader and nuts tacked
4
Welded in
Welded in
5
Some duraglass and it's a wrap
