If you are not familiar with the location of my shop, it's in the south part of Berea right near the turnpike and turnpike building. Spudnuts Donuts is about 200 yards north of me (Prospect and Sprague). My address is 686 Prospect, Berea, 44017, which is also State Route 237. It's right near the turnpike crossover on 237, the turnpike building, about 1.5 miles south of Berea downtown, and 2.5 miles north of Rt 82 Strongsville.
BUT- DON'T go to the front building which is marked 686, they won't know what you're there for. Turn down Greenfield Court, drive 100 yards, and turn right through the gate. If you're using GPS a better address might be 16 Greenfield Ct, Berea, OH 44017. You won't miss my building.
Rain or shine, we'll see you there Saturday May 12th! There's no specific time, I'll roll in about 8:30 or so, most people will probably drift in about 10ish. There will be hot dogs and maybe other stuff, and some people will bring donuts. Spudnuts is walking distance if you forget.
2018 Tune Up Day - May 12th
Re: 2018 Tune Up Day - May 12th
I would like to do a leak down test and compression check on a 1600 SP motor.
If you need tune up parts, plugs,wires,points cond,cap. call Mick at Euclid Foreign 440 465 1985. try to have your distributor #,
Also, I have a supply of shift bushings for most buses,if you have a sloppy shifter,this is a good opportunity to fix it.
- Frankinbus
my drivers door bottom hinge is tearing off at the rivets. my bentley manual says to weld the rivets on the inside and put a reinforcement plate on , they even have a part number for the plate. also the piping at the top of the door card came unstapled, does someone have a small stapler for that. thanks
65 11 window bus
2012 turbo beetle
1964 berry mini t buggy
2012 turbo beetle
I have the stapler,will bring.
- Karl Kombi
I know there was some talk of moving Tune Up Day back due to Bruce's schedule. Is it still Saturday morning?
Thanks!
Thanks!
Yes. No changes. We are still on for Sat.
I plan on picking up some donuts. The hot dog machine will be rolling. Come on out and chat even if you aren’t planning on working on a project.
I will be bringing a couple of bags of McDonald's breakfast foods and an assload of cheap beer.
