The battle of Michigan is on!toolbox wrote:Ditch the Ford solenoid, it takes almost as much current to trigger as the stock unit. Use a Ghia 6V horn relay or find a 40A 6V foglight relay.Keith wrote: The old 6V Ford solenoid trick, explained in rich detail with a Peter Aschwanden graphic in the John Miur "Idiot Book", will help, too.
Thanks guys. Problem occurs under hot or cold conditions. I'll clean the strap short term and probably get a replacement strap from Kyle since I've changed everything else.
I have four or five extra 6V starters/solenoids. I think I even have a new one in a box. I'll pull them out and check. Kyle redid all the wiring so I don't think that's the problem. See all the fun you're missing by not running a 6 volt system?!
Here's the update. Cleaned tranny ground strap. Problem not happening as much. Tried to start it about 6 or 7 times it only did it once. It's probably the starter. In any event, here are some pics for newbie's like me to help with finding and cleaning your tranny ground strap.
Very dirty...
Even the Cat said it was bad...
They clean up nicely with some elbow grease...
It's important to clean up the area they connect to on the body and tranny...
I found two of the 6V starters I have, (what happend to the tranny bushings?
Now that Keith works for Ford, Kirk and I will keep this around to keep Ted on edge.
