1978 FI AFM needed
1978 FI AFM needed
Hi all, Howie's widow, Lorrie Snyder, asked me if I had an AFM or knew someone who had one to get his 1978 bus running again. I should have attached the photo of the part number. If anyone has one to buy it would be greatly appreciated. I sent her a few links to discuss with her mechanic but also want to look locally.
Thanks
Edit June 23, 2025: one was found. Post can be removed
Re: 1978 FI AFM needed
Send the current one for rebuild.
https://www.bavrest.com/air-flow-meter-service.html
You might get lucky at swap meets. I’ve seen a few in the past.
