WideFive wrote:I can make it fit
i agree...needs to sit a bit lower
Nope.Josh wrote:Well...does it fit in the garage/shebeen?
I'd rather jack hammer the driveway first!vw7266 wrote:i agree...needs to sit a bit lowerWideFive wrote:I can make it fit
2Xwwebner wrote:I hope you moved that B ball hoop before this wind started up. Ours took out a windshield on one occasion and did a number on the hood on another,even when it was fully weighted.
All good points Marc. On the other garage bay there's no door opener, so I may just move it over there. I've just got to remember not to have anything on the rack when I'm puling in!abuspilot wrote: Some garage door advice though.
1. I would always have a spotter and pull in and out slowly.
2. If a spotter isn't available, I would push the bus in by hand, so you can be the spotter too.
3. Don't increase the travel limits to the opener to pull the door back further than it is designed to. The result will be a thrown cable, possibly a bent up door / track and damaged parts.
4. Make sure the GDO disconnect cord is either off or rapped around the arm (hockey stick looking piece). Nothing would be worse than the opener ripping off the rack tubing.
5. REPLACE THE GENIE FOR A LIFTMASTER.
