77 Westy
Re: 77 Westy
I got about a hundred miles out of the bus until the fuel tank rust prevailed. I was losing power and bucking/stalling, so out came the motor and tank. The tank was heavily caked all around with huge rust flakes. A local radiator shop didn't even want to touch it, but luckily Sean has a good spare that will work fine. I am probably going to do a little clean up while the motor is out, but nothing major. I'll save that till the end of season.
This was my first type 4 motor pull, and it was just as easy as a type 1! Only took about an hour, but I am sure that installation will take a bit longer.
I have to say... I love fuel injection. I know Don is smiling now.
Green...77
Re: 77 Westy
Post by Green...77 »
Image[/quote]
Nice bus! :D
Be careful when you reattach the double relay and resistor pack. They get brittle after 34 years. I've had to solder both after disturbing them.
Mark
Re: 77 Westy
Put a 1600 in it and run it.
Re: 77 Westy
I would if I had one...
Re: 77 Westy
You should just go over to Kirk's house and take that red bus back. And tell him tuff luck buddy. :shock:
Re: 77 Westy
Josh will have this back on the road in no time once his new parts arrive. Nothing holds that man back. :)
Re: 77 Westy
Ron wrote:You should just go over to Kirk's house and take that red bus back. And tell him tuff luck buddy. :shock:
I like that idea too......just bring some cash ;)
Re: 77 Westy
So since the engine was out, I wanted to go over a few things. I took the tin off and saw a lot of the old deteriorated engine seal caked on to the cylinders and oil cooler. A few hours and a gallon of simple green things are looking good.
The gas tank is rusted to hell, but Chuck is confident that he'll turn it into a beauty queen. Meanwhile, Sean hooked me up with a like new tank. I have a bunch of little parts on order that I need before the engine goes back in. I am going over Chuck's to sandblast all the tin, then I'll give them the rustoleum treatment.
This engine is in great shape, and doesn't even leak oil.... yet.
and after............
Re: 77 Westy
Nice bus and good looking work josh! If I cleaned one that good it would probably start leaking
Re: 77 Westy
westy66 wrote:WOW! clean.... did you use Amanda's toothbrush ;)
OUCH! :lol: :lol: :lol:
>I< was going to ask, "Did you have that done at WideFive's shop"? ;)
