Re: CKWA/KWHA Part II
Posted: Fri Aug 07, 2009 7:18 am
Mystery solved......
. Thanks Todd.
Actually all the type 1 style transmissions have 2 drain plugs.Six Volt wrote:
BTW, isn't it crazy that it has two tranny drain plugs???![]()
Todd, you are going to hell now! Just wait till the oil nazi's see this!bastardbus wrote:As well always make sure you only use GL-4 rated gear oil in your air cooled vw trans and nothing rated GL-5 or higher as they contain additives that will corrode-eat away at the yellow metals in your transmission such as your gear syncronizers.
Actually, I like the way Sean did it originally, even if it is not correct. But what do I know?toolbox wrote:Sean the radio faceplate is on incorrectly. It installs behind the dash filling the space between the dash opening and the radio.
No moisture barrier!westy66 wrote:good work on the door panels. did you install a moisture barrier? if not, those things are gonna get warped next time you drive in the rain
The only thing "wrong" is not giving that bus enough exercise on the road, and driving it out to some events. Quit tinkering, and start enjoying it.Six Volt wrote:BTW, I appreciate the support about the radio plate Howie, but there are enough things wrong on this bus as is!
Bob is right, that bus had been passed around and neglected for sooo many years, I don't think it could have found a better owner then you.westy66 wrote:Hey sean.. Nobody is nit picking. That bus is awesome and any one of us would love to own it!
