Page 19 of 27
Re: Rick's 1969 DOUBLE CAB
Posted: Sat Sep 25, 2010 1:32 am
by vwrick69
This thing steers like a semi with the power steering unhooked. I really have to wrestle the wheel.
Posted: Sat Sep 25, 2010 7:59 am
by Randy
Before you go buying stuff, check all your steering components, ie drag link, steering box, tie rods and center link pin in the beam.
Randy
Posted: Sat Sep 25, 2010 8:27 am
Randy wrote:Before you go buying stuff, check all your steering components, ie drag link, steering box, tie rods and center link pin in the beam.
Randy
Also check the swing pin to make sure it's not binding or too sloppy. As Aaron said the toe-in is also important.
Posted: Sat Sep 25, 2010 8:31 am
by vwrick69
Steering box and tierod ends are fine. I had the draglink unhooked to center the front tires and the steering box turned very freely. The drag link ends moved without a lot of trouble. A couple weeks ago I put new rubber boots on tierod ends and more grease while I had boots off. The center pivot has a little movement up and down, but I have not had it isolated by itself. So I am down to balljoints. Ever since I bought this it has been a mother to turn the wheels wheather the steering wheel was hooked up or not. 20 years of sitting, they either set up or were not installed correctly is my current frame of thinking.
Posted: Sat Sep 25, 2010 8:34 am
by vwrick69
This thing even turns hard with the front end off the ground.
Posted: Sat Sep 25, 2010 9:02 am
by Howie
Congratulations! This thread has hit the "20 Pages" mark.
Posted: Sat Sep 25, 2010 9:05 am
Posted: Sat Sep 25, 2010 9:06 am
by Howie
WideFive wrote:Howie wrote:This thread has hit the "20 Pages" mark.
Which means absolutely nothing... just like a person's post count
Jealous!
Posted: Sat Sep 25, 2010 9:17 am
you can just trailer it to KI
Posted: Sat Sep 25, 2010 9:18 am
by Don from Canton
There's a lot of complaining over on the IAC web site
http://www.itinerant-air-cooled.com about new ball joints being extremely tight. (Go to the Suspension Steering and Tires forum and search around.) The running theory is that everyone is making the replacements to the large size and they get pinched tight when pressed into an on-spec hole. The recommendation there is to nurse original ball joints as long as possible, but that's not an option for you, I guess!
Scott at German Supply was mentioned in an earlier post - I think that's a good option. Scott seems to be a very quality-conscious guy.
