Page 3 of 18
Re: 1957 Oval
Posted: Mon Feb 20, 2012 1:04 pm
Well, this is the slowest project EVER. :cry:
The tranny still needs to be put back in with a replacement nosecone, (thanks Bill), new bushings, hockey stick & mount to allow a later tranny in an earlier oval bug. I've got all the parts now just need to get it done.
In the meantime, I've been sorting through the rough headlight assemblies I have.
I'm going with the original stock 5pm 7pm standard screw slots with the tension arm.
Once you get these early babies apart it's usually not pretty.
Hopefully they'll come out alright.
Re: 1957 Oval
Posted: Wed Feb 22, 2012 5:16 pm
by Randy
Good job. Wish I lived closer.
Randy
Re: 1957 Oval
Posted: Wed Feb 22, 2012 6:45 pm
Well, I had a couple hours this afternoon so I figured I better try to get these headlights together. I had a lot of crusty Hella and VW set ups from '66 and down from both bugs and buses to choose from, (thanks to everyone who helped me out with parts), but I decided to go with the original Hella style, (5pm and 7pm flat blade slot adjuster screws), with the tension bar that were in the original Ovals.
This process is not Widefive approved, :lol: but seeing as how I couldn't find any really nice used ones and the NOS ones are pretty pricey, they'll have to do.
So here's how I did them in case any of you have to go through this down the road. The veterans can point out any of my errors so you don't repeat them. :D Oh and always use safety glasses like Kirk always uses. You know, OSHA approved. :lol:
From reading Bruce's tech articles, and seeing how clean & organized Aaron's place is, ;) I figured I better clear and clean a place to work.
I started out lining up the smaller retainer ring with the bulb. You need to line up the "bumps" on the backside of the bulb with the slots on the ring. But that's only part of it. You also need to think ahead and be sure the logo on the bulb is in the right spot in relation to the housing so it doesn't look stupid when you finished. :oops: Ask me how I know. :roll: And if that isn't enough you also have to be sure the small retainer ring is lined up with larger retainer ring that all goes into the housing. :? If you're confused, don't worry, you usually figure it out after about 7 or 8 tries. :lol:
When you mate the smaller ring, (along with the bulb), to the larger retaining ring, you've got to get the tabs in the right spot and also line up the connecting "post" on the larger ring so it all fits together snuggly. Look closely, you can see one of the small tabs in the center of the picture.
You've got to "mate" all three, (small retainer ring, bulb & larger retainer ring), together and be sure the bulb logo is right and the connecting "post" is right. It's not easy because they want to fall apart despite your best efforts to hold them together. :o
Now the fun part. You've got to hold it all together in your lap to get theose *&%$#@ clips in palce to hold it all together. :evil: Those little buggers like to fly, (incoming!), so be careful and be ready to hit the deck of one of them gets away from you. There are basically two kinds of clips. This part uses the ones I call "V" clips because they have a "V" on one side. Here's how you put them in.
You put the "V" side under the rim then force the other side under the rim.
Hopefully, you still have both your eyes when you get them in. 8-)
So now we've got to mate the bulb and retainers to the main housing. Look closely and you'll see the hole in the main housing and the post on the retainer where the two come together.
You need a rubber washer and "C" clip to put them together. (I found acceptable replacements at Loew's)
Here is the "post" in the hole with the "C" clip about to go on. Gee I wish I had a sandblasting cabinet like Kirk. I should have done a better job on that, but it was pretty crusty and it won't be seen. :oops:
Once attached the bulb housing is now "attached" to the main housing.
You can see how the little rubber washer gives you both cushion and separation.
Before moving on you've got to check and make sure your bulb is centered properly with the logo in the right spot. Ask me how I know. :oops:
Now you can clean you glass and put your new rubber seal on. I got mine from WCM.
Next is get your outer chrome ring and clean it up with Brillo or SOS and put the glass with it to line it up.
You can see where the parking light bulb assembly goes, but before that pay attention to the two groves on the retainer housing.
These take these little adjuster mounts that hook in those slots and are then held in place by the adjuster screws. Here's what they look like.
Clean up your 6 Volt housing real nice and get those wire connecter screws ready for action!
One screw holds it in place.
You can see what I mean by the 5pm & 7pm screw locations. Some of the other pre 67 bugs & pre 68 buses had the screws at 2pm and 8pm. Also bus housings had a drip hole on the side.
Now on the old Oval set ups, a kind of tension "pry bar" is attached to the housing that pulls the bulb in or out when you turn the screws at 5pm & 7pm to adjust the light. Other set ups didn't have a tension bar, they had a long and shorter clip that mounted on the retainers and were controlled by the screw action. Here's what the tension bar set up looks like.
Still got your eyes? :roll: We'll we have one more chance to loose them. :lol: More of those &^$%#@ clips for the outer ring to be connected to the main housing. These are a slightly different shape than the earlier "V" clips and have a little "squiggly" notch that allows it to rest on the housing once in place.
You've got to put your rubber seal on the car. I can't figure out the best way. Trial and error. Aaron probably knows. Maybe he'll tell me. :lol:
Well, I guess this is enough for old Six Volt until something better comes along! :lol:
They don't look too bad. Now I need Kyle to tell me how to wire it up! :lol:
Six Volt OUT! :lol:
Re: 1957 Oval
Posted: Wed Feb 22, 2012 7:08 pm
by Randy
Nice!!!!
Re: 1957 Oval
Posted: Wed Feb 22, 2012 7:47 pm
The last time I did that job was on the 63 SC a few years ago. Brings back fond memories. Ouch. Will be doing the Vegas bus real soon also, nice refresher course.
Re: 1957 Oval
Posted: Thu Feb 23, 2012 8:26 pm
Well, I've been tripping over the transmission on the floor all winter so I decided to go for it. I was going to put a split case in, but it never materialized up here. My other option was to go down to Athens for a Schwindeman model, but for now I'm just bolting the '61 model year back in. Spring will be here before we know it.
Putting a later fully syncro bug tranny in an oval requires some modifications. The good news is the best method is just changing parts and then it's a straight bolt in. No hacking or welding required.
I needed to change the bug nosecone to a '60-'67 bus nosecone (thanks for that Bill) put in new bushings and get a replacement hockey stick from WW with the screw hole on top. Also the right gasket and set the forks right and a new bus mount that bolts between the tranny nosecone and the body.
I got a little intimidated with the thought of setting the forks, so I did like any rank amateur does. :oops: I loaded up the tranny and ran it down to Dale's to get his input. :lol: 10 minutes later he had me "good to go". :D
While I was there I got the boots changed and put a new starter bushing in. Six volt of course! :lol:
Here's what's under a nosecone.
Here's a close up of the forks.
Here's the old bug nosecone.
And the replacement.
And new boots.
Hopefully it will work! :lol:
Re: 1957 Oval
Posted: Fri Feb 24, 2012 6:39 am
by Josh
Awesome! Now you can start moving forward with that project. You think she'll be ready for the metroparks cruise? :P
Re: 1957 Oval
Posted: Fri Feb 24, 2012 8:21 am
Josh wrote:You think she'll be ready for the metroparks cruise? :P
Yea, in 2013. :lol:
Re: 1957 Oval
Posted: Fri Feb 24, 2012 10:54 am
by vw7266
nice work...Ive alwasy been told not to put the axle boots the way you have them.
Ive always heard you were supposed to put the seam where they meet on the side not on the top.
But everyone has an asshole I mean opinion
Re: 1957 Oval
Posted: Fri Feb 24, 2012 11:41 am
by slayer
vw7266 wrote:nice work...Ive alwasy been told not to put the axle boots the way you have them.
I believe you are correct..like 2 a clock or 10 a clock!
I also have an a$$h@!e, i mean an opinion!
