Re: SC
Posted: Mon Dec 31, 2012 7:39 pm
People tell those kind of stories all the time, but it never happensvw7266 wrote:you know your lucky enough to just roll up the interstate off ramp and into the station on the last drop!
6. Fix reserve tap...CraigOnTheBoat wrote:1. Charging System - Check
2. Clean Fuel System - Check
3. Turn Signals , Brake Lights , Running Lights - Check
4. Enough Gas to get uptown and back with wife - Unchecked
5. Walk home to get gas can and ride back - Check
lol6. Fix reserve tap...
If you still have it it only takes about 20 minutes to R&R. The new ones sold are backwards, cable out is normal and cable in is reserve.CraigOnTheBoat wrote:lol6. Fix reserve tap...
Took it out because it was fugged up. Bypassed it, but I think I will be putting a new one back in so I dont have to carry around a pencil and paper.
Spare 1 Gallon can will also be added.
Ted is 100% right. He walked me through the rebuild process on my '59 after he noticed I had some beetle fuel valves in my stash and I couldn't identify the correct bus version. I doucmented the process on the old site, but I don't think it's available any longer. I was able to get mine to work right because WW still sold rebuild kits for the bus version at that time. If you have a bus valve, you may be able to rebuild it so "in" is normal and "out" is reserve, but you have to take it apart and see what's damaged or missing. Here's the replacement one from WW http://www.wolfsburgwest.com/cart/Detai ... 211209021E and here are some of the parts that are usually bad that you can still buy. http://www.wolfsburgwest.com/cart/Detai ... 111209113Atoolbox wrote:If you still have it it only takes about 20 minutes to R&R. The new ones sold are backwards, cable out is normal and cable in is reserve.CraigOnTheBoat wrote:lol6. Fix reserve tap...
Supposedly the 356 tap parts that are made of cork last longer with our recent crappy oxygenated fuel.
One would think that if you were going to make a replacement why would you make it in reverse??!! What would be the reason for that?toolbox wrote:. The new ones sold are backwards, cable out is normal and cable in is reserve.
They are for Bugs, you can pull the tubes and swap them and all is good.slayer wrote:One would think that if you were going to make a replacement why would you make it in reverse??!! What would be the reason for that?toolbox wrote:. The new ones sold are backwards, cable out is normal and cable in is reserve.
I have a WW one and I don't use it because I don't want to have the knob pulled out all the time!
My reserve is a extra gallon of gas I carry in the bus.
