Page 3 of 6
Re: 1971 Early Bay Panel
Posted: Tue Dec 17, 2013 12:20 am
by Busjunky
Made a useable seam out of the corner. Klokkerholm boo yay!!
Posted: Tue Dec 17, 2013 12:21 am
by Busjunky
Corners in and i replaced that wall while i was at it.
Posted: Tue Dec 17, 2013 12:22 am
by Busjunky
Then i did the long side rocker. The cheap panels do not have the seam in them so i made it by hand.
Posted: Tue Dec 17, 2013 12:23 am
by Busjunky
I cut it into two pieces and made 90 degree bends in it to create the seam.
Posted: Tue Dec 17, 2013 12:26 am
by Busjunky
Then i recreated the panel wall seams by using a chisel to offset the sheet steel. I cut those slots in it so it wouldn't bind when i bent the radius.
Posted: Tue Dec 17, 2013 12:28 am
by Busjunky
I rebuilt that B pillar by hand too. Here it was all fitted in. Looks alot better now that finished it up. This was done awhile back.
Posted: Tue Dec 17, 2013 12:30 am
by Busjunky
Go the driver side corner removed and the rear wheel well area. I made that corner the same way as the other side.
Posted: Tue Dec 17, 2013 12:31 am
by Busjunky
I made that lower fender piece by hand. Re-werked klokkerholm corner. I also deleted the reverse lights.
Posted: Tue Dec 17, 2013 12:34 am
by Busjunky
Replaced the slider track. Pita.
Posted: Tue Dec 17, 2013 12:37 am
by Busjunky
I decided to slam the piss out this thing. So i had to tub the rear wheel wells. Well the gas tank was in the way so i had to move it to the upper left hand corner.
