Vanagon Conetastrophy
obsoleteman
Re: Vanagon Conetastrophy
I see all suggested explanations as plausible.
But, My knee jerk reaction is the shift linkage being struck.
The clean shear is a statement and story in itself.
I have seen cars that had some rather odd damage during my years in a tow truck.
High speed shifts into the wrong gear did sometimes remove flywheels, twist drive shafts, crumble differential components, or even remove complete transmissions (broken from the engine at the bell house) . Some cars crashed.
I fixed a few cars with broken flywheel bolts. But I seldom heard the drivers story.
If you are lucky, it may be that it failed at a weak link with little damage.
I would be anxiously Draining the gear lube for clues.
If you were so lucky to have weak flywheel bolts during an unplanned downshift, you will get to laugh about it some day.
For it is worth, I was an insurance adjuster for 13 years in the property and casualty field, you more than likely have coverage for this loss if you have collision coverage on your Auto Policy. Of course it would be subject to a ded. so if it is less than that mute point.
Trying to get caught up on my postings, The Levine Vanagon has been repaired, Engine rebuilt, replaced crankshaft & flywheel, new bearings, seals etc... Transaxle tore down & inspected and 3-4 slider hub upgraded,
Short block on stand awaiting piston removal
Water pump wrist pin access hole
Again
One of the 4 rolled waterjacket o-rings
Wrist pin waiting for extraction
Cleaned & prepped engine case ready for reassembly
Internals
Heads & cylinders
Rods hung
Gears on crankshaft
O-ring washer and pulley key installed
New cam bearings, double thrust
Checking the fit on the camshaft, We have had some issues with cam bearings of late, Check them first!
Crankshaft in case
Then the camshaft
Cam plug
Again
Internals
Heads & cylinders
Rods hung
Gears on crankshaft
Crankshaft in case
Then the camshaft
Cam plug-
Cam timing confirmed
Other case half ready for reassembly
Curil K2 sealant
Mated
One of the main case studs, inside the water jacket
Cap nuts with special yellow sealant
Wrist pin installation/removal tool
Piston in cylinder
New o-ring with lube
Piston skirt ready for installation
Wrist pin being installed through water jacket port
45 degree Knipex retaining ring pliers
Cylinder head, slightly abused
Ready for cylinder head, water jacket gasket installed with sealant,head gaskets in place, pushrod tubes installed
Head installed
Repeat
Water pump & thermostat housing (1.9 liter type)
Pushrods & rockers
Crossover pipes & dipstick tube, more to followRe: Vanagon Conetastrophy
Nice work Chuck and we'll documented of course.
Cheers
Cheers
I would like to point out those perfectly stretched out pushrod tubes!
Off the engine stand, installing flywheel
Confirming initial endplay (.09mm)
Main seal installed
Flywheel installed checking final endplay
Final endplay (.08mm)
Clutch & pressure plate installed, Engine complete.Who is online
