Page 3 of 3
Re: Pumpkin the 1977 Westy
Posted: Fri Oct 31, 2025 6:00 pm
by Karl Kombi
Bravo!
Posted: Sun Nov 16, 2025 2:45 pm
by TRL
So, I have heat! It needs refining in places but it works! I was pleasantly surprised when I reinstalled the Blower fan that the everything worked correctly. I’m not happy with the fitment of the blower tubing down to the heater boxes. Need to work on that a little or find other tubing. I ended up using some of the original broken tubing to piecemeal it all together. Underneath the bus, I installed the new heat control flaps and hooked up the heater cables. When It came to flexible heater bellow tubes. I pulled some original ones apart. Removed asbestos seals and hand washed the insulation to removed years of dust. Reassembled and reinstalled with new silicon seals on each end. Original bellows are much better quality then repop ones.
Still need to fiddle with a few things like the directional flap box underneath the middle of the bus. Happy to have some warmth!
Posted: Tue Nov 18, 2025 9:22 am
by Marla
Heat is always a good thing.
Posted: Wed Nov 19, 2025 5:47 pm
by chuckspence
Heat in a bus is overrated, nice exhaust & heat exchangers, way to stick with the og triangle flange units with the F & U pipes! Did you change all that schmangled engine tin?
Posted: Thu Nov 20, 2025 4:40 pm
I'm a freeze baby. Both of my buses have great heat and I wouldn't have it any other way...
