I unloaded my camera of pics I've been taking for weeks (hundreds of them) to find more than half unusable due to dirt behind the lens. For those who've seen the bus or were at the cruise today these are old news. For others, here's an update:
Step one in wiring the dash is to install sound deadener in that area, since once the harness is in there's no easy way to get behind it. Here's some Fatmat stuck in place to keep the noise down. It does a really good job, as the bus has about a hundred miles on it right now and it's very quiet in spite of not having any weatherstripping on the doors yet!
I don't like the way VW runs the power lead to the fusebox, then to the HL sw, then finally to the ig switch. I soldered a three way split into the wires so each of those items is fed directly from the 10ga feed wire and put heat shrink tube over it. Remember this feed has a 40amp MaxiFuse in it for protection in the back of the bus.
This now feeds the ig switch directly. I put heat shrink over a lot of the factory terminals and use almost all sealed connectors even though they're not exposed to the weather. The shrink connectors give a much better mechanical connection resistant to vibration. The fuseboxes (yes, two) are installed but completely detailed yet. I'll shoot better pics once it's done and put them up. It looks kind of crappy right now (you'll remember from Bill's pics with the test light :shock:
I bought a good used fuel gauge off of Samba, buffed it, and installed it. Gas guage works!
Popout prep and install took a lot of my time over the last couple of weeks. They are kind of a PITA to assemble and install, but that's cause I'm a diesel engine guy and not a body/glass/interior kind of guy.
Here I'm painting the frames with the same PPG paint I shot the upper part of the bus with. That's a Parma Spray Booth ducted outside with an exhaust fan. :) Painting those things is probably the worst- trying to get all of the inside and outside surfaces. Powder coating is another option but the added thickness makes them a lot harder to assemble.
Getting ready to assemble, it's pretty straight forward. I just don't like doing it. I cleaned the glass per Lurch's advice with (???) glass cleaner (no ammonia) and 0000 steel wool. I then ran the buffer over them (the big one that I buff the paint with) with some fine compound, you can feel a big difference between buffed and unbuffed glass with your fingers.
Assembling the glass to the frames went really easy- no clamps needed, just Windex and light muscle. The Samba powdercoat gang has to use massive clamps and BS to get the screw holes to align. Me? Push it together with Windex and the screw holes lined right up. No grief at all. I used several old frames and two new aftermarket frames, which fit nearly 100% perfectly. I'm amazed at how good of quality they were. If your frames are rusty don't even bother cleaning them, for $35 you get a new one. I couldn't even tell which was which except the hinge-to-frame threaded holes were just a bit sloppier and I stripped one out with light torque from a screwdriver.
Putting in the outer seal in the frame was easy, but a plastic gasket scraper made it easier. The screw holes visible just under the scraper are the ones that were just a bit sloppier than OEG. Once again, Windex was my only lube. (as Lurch cringes....) From here it's just a matter of pushing the assy into the bus and screwing in the screws. A little kid could do it.
Here I'm fixing the rotted sockets in the taillight housings, I used Napa PN 787146 which is a universal 3 wire taillight socket for an 1157 bulb. It has its own ground wire so you don't have to worry about socket-to-housing-to-body continuity for ground. Put it together and screw the ground wire to the body in a normal way. The only thing is it's about 1/4" larger so you have to drill/file/hog/ or use whatever tool of destruction you prefer to open the hole up a bit. I used a drill press.
Once the socket is installed, the little tabs are bent over to lock it into the housing.
OK, the socket is in but the chrome is icky that reflects the light. No trouble, use the tried and true hillbilly method of gluing aluminum foil in place with spray glue. :lol: First, spray the glue and push it into place.
Then trim off the excess with a razor knife.
Once done, the foil works great and the lights are nice and bright. Sean followed me today, he can probably agree. In the background you can see the front turn signal bulb holders with which I did exactly the same thing. Bead blast, glue, foil, new lenses, install. The sockets on the front ones were fine, requiring no repair. All four are nice and bright.
The buffing wheel came in handy for dozens of small parts. Switch bezels, light bezels, even the taillight lenses responded greatly to a spin on the wheel.
Here's half of a lens done showing the difference between old and new. Amazing!
Bill's interior work is EXCELLENT! He fabbed up these "seat stand covers" where the stands would normally have painted metal looking at you.
Probably 875 hours right now. Still to come in no particular order:
Front window frame refurb and paint
Front and rear bumpers
Spare tire, jack etc.
Install all weatherstripping
Headlight assy refurb
Interior light assys
Detail fusebox area, mount TS flasher, modify and install front kick panels
Front door panels
All Deluxe exterior trim- straighten, wetsand, polish, install. (Ugh! Not more bodywork?!)
Steering wheel refurb
Finish carpet padding, install rear seat.
Finish popout latches and some of the inside popout rubbers.
Oh, yea, and don't forget the phucking tranny. :(
It has definitely come a long way and going into the final stages must feel great.
One question though:
How did a tranny from Phucket, Thailand wind up in your bus?
Helmet
Post by Helmet »
Very nice find.
Have fun with the restoration.
Looking forward to progress photos
Man bruce the bus realy looks awsome I like the interior choices you made.colors come together very well. You must have been grinin ear to ear leadin the pack yesterday in the park.:)
Helmet
Post by Helmet »
It is going to be a museum piece and to nice to drive!
Time for an update. I ditched the bad camera and replaced it for $5 off Fleabay.
I added a power outlet under the dash on the right side. I'm actually thinking about tunes! Cip1 has a specific radio/MP3 player that fits a bus for $159 that looks good, I'd like the real retro look ones but I don't want to spend $500.
http://www2.cip1.com/ProductDetails.asp ... D155%2D135
I finished the dash wiring and did what I could to clean up how it looks, but you just can't make these look pretty using a factory harness.
I cut a hole in the kick panel for the second fusebox and mounted the kick panels. I also cut the hole bigger for the speedo cable and put a grommet in, this allows me to remove the dash tray without completely removing the speedo cable. Obviously, I also installed the speedo cable so now the speedo works fine.
My upper steering shaft bearing had some side play in it, so I figured this was a good time to change it. Luckily the old one pulled out with a pick rather easily.
The new bearing taps into place easily with the proper size socket.
The new one comes with a new (longer but softer) spring, I also changed the keyway and nut.
On to the RF window frame. Disassembly was rather easy but I did have to torch some of the small screws.
Put the vent window in a vise with rubber and pry the frame off of it.
Clean and paint all of the stupid little parts. Frames are a pain to paint because of all of the sides and edges.
Here it is partially assembled.
This "13 window" bus actually has 17 pieces of glass to clean 50 years of grime from, and it don't come off easy. First, a razor blade and window cleaner
Then 0000 steel wool.
And I ran the buffer over the glass with fine compound to give it a nice shine. I have hours and hours cleaning all of the panes (pains).
Riveted a new latch in.
The vent glass went right in with silicone- only light pressure needed. On Ed's and Lurch's advice I used an extra popout glass seal.
Here's the RF door done, panel installed, etc. I can't believe how many hours I have in this stupid thing, I hope the LR door frame goes faster. Installing the vent rubber and door panel is a real PITFA. I don't know how body/glass/interior guys do this shit all day long.
I acquired an old Bilstein jack. Does anyone know how to lube the gear mechanism? Lubing the screw is easy. There's a rubber cap that I'm afraid to take off.
Sean donated a spare tire, cleaned up and painted it looks great.
I bought a spare "supposedly good" (?) tranny last year with the axles off, now I'm trying to make this basket case a tranny again. :roll:
Fugly dirt
I spent hours cleaning the grime off the housing, I didn't want to pressure wash it for fear of water intrusion. The good news is that it came from a southern bus, no salt rot at all on the bottom, and a mixture of Georgia red clay and sand stuck all over the case. Tedious time with a scraper, solvent brush and brakeclean to finish it off.
Does anyone know were to buy the axle tube retainer O-rings? (not side cover O-rings) These don't come in the tranny gasket kit and WW doesn't show them. Also, where do you buy tranny inside parts? WW only shows really early tranny parts.
Next, LF door frame and then bumpers. Still need to finish carpet and rear seat sometime, too.
Sexy....'cept for that auxiliary fuse block ;)
Really awesome work Bruce. It looks spectacular.
I'm very impressed with the detailed "up front" electrical work and would like you to elaborate a bit more on those improvements if you get a chance. Maybe an COVVC newsletter article? Or just post something with a little more detail here.
The "fusing" of differing parts of the bus electronics is interesting, but beyond my comprehension. Nevertheless, I'd love to learn.
Tranny parts........there is a guy in pa. geno boyd, I delt with him a few years back he is pretty reasonable. get on thesamba..
seller name genoboyd..he treated me well, you may find what ur looking for...I just checked he's still selling parts on there...
I've done a few things, time for an update. Many of you have seen the bus lately at cruises and events but not everyone. First of all, I completed painting the LF door window frame and installed it, which went much smoother than the RF for obvious reasons. I installed the door panel which also went much smoother. I also installed the weatherstripping around all doors.
The interior is looking quite nice.
The weatherstrips from WW for the front doors, rear hatch, and engine lid all fit perfectly. The weatherstripping for the cargo doors was too thick and skewed the door alignment so badly I had to remove it and use Home Depot generic stuff, which actually fit quite nicely. The Samba guys bitch about the same thing.
The rear carpet is finished off and the rear seat installed, I found out the hard way the seat back has to be installed before the seat base. :oops:
I straightened, mudded, painted, wet sanded and buffed the front bumper, and installed it.
Ditto for the rear but sans overriders and towel bars, I bought those new and they just arrived and have not been painted yet.
It's about 95% done right now with mostly trim left to do, I bought the RetroSound $159 radio with MP3 player but have not installed it yet. Still struggling with the 3 speed and a Rancho box with a 5 year guarantee for $699 is sounding better every minute. It drives very nicely but I still don't go much over 58-60 on the highway as the engine is really twisting, and going from a 4.37 to a 4.12 would help that a tad. The extra insulation really paid off as it is really quiet to ride in until you're up to speed on the highway. I'm probably about 950 hours right now and amazed how close it will be to an even grand for completion.
8-)
