The "Lurchmobile"
Randy in Maine
Re: Mechanic Needed - 78 Bay
I am dying to know what the problem was and how you figured it out.
Can you share?
Can you share?
As Aaron pointed out, Dale is the one who fixed it. I did a good job of getting in the way!Randy in Maine wrote:I am dying to know what the problem was and how you figured it out.
Can you share?
It was cranking slowly because of a bad battery ground so Dale cleaned that and added a supplemental ground directly to the engine block in addition to the normal battery ground. Also the screw holding the ground for the double relay on the firewall worked itself loose and we were not getting a good ground there. There was also a distributor problem. Timing was adjusted, oil changed and it fired right up. Runs strong.
It's probably going to need another AFM.
Interesting it had been sitting for a few months and all 4 wheels locked up. We had to pull both rear drums at Dales and replace one of the shoes and free up the adjusters. Rolling now, but needs some work.
Re: Dan's old ride.
I heard that this bus is no longer for sale, can you shed any light on that Sean?
Re: Dan's old ride.
Oh Chuck, your wonderful, witty sarcasm knows no bounds!chuckspence wrote:I heard that this bus is no longer for sale, can you shed any light on that Sean?
It's all on the QT, but word on the street is some idiot overpaid for it.
Re: Dan's old ride.
When are you going to convert that Bay to 6 volts?
Randy in Maine
Re: Dan's old ride.
Yes it is usually something fairly easy like that. More VWs have been towed for bad electrical connection than everything else combined.
Actually not a bad looking bus. I have always liked the sliding center windows.
I don't know how old the rubber brake lines are on there, but on my "new bus" (and I will be updating my thread shortly) I am going to be using these for the hoses....
http://www.aircooled.net/new-bin/viewpr ... 1154469980
Re: Dan's old ride.
Congratulations, Sean!!! Another full-restoration project?
"...the ones in love with the night, they light up like a cigarette." -Jack Kerouac
Re: Dan's old ride.
I think I need my head examined.
Dawn's first comment: "Does it at least run?"
