Page 36 of 36
Posted: Fri Jul 10, 2026 9:02 am
Thanks guys. I will take a closer look at it. I am heading to Jim's this weekend so maybe I will find something there.
Posted: Sun Aug 02, 2026 11:58 am
Update: I changed out the coupler for the one purchased at Jim’s. The coupler we installed from WW looked fine but thought I’d try it regardless. Same results.
Did a couple of tests with it running up on jack stands and shifting it without the shift rod linkage to eliminate that as a variable. It seemed to be Ok but hard to tell. The next attempt was to loosen all connections of the transmission to the frame and engine to see if we could get a better alignment to the front link arm. We wiggled a minor amount. Connected everything back together and took it for a ride. Same results.
So for now, I am going to leave it alone. When or if I drive it I will have to manually keep 4th gear engaged. At the end of the day I have no other option but to tear it down again to see what’s going on. That will be a winter project.
Thanks to those who have helped trying to troubleshoot this with me. A lot of time has gone into the issue, much appreciated.
Posted: Mon Aug 31, 2026 10:04 am
While the transmission situation is still getting situated, I figured I’d go ahead and finish up the interior of the bus. Cleaning up overspray from the painter and replacing curtain tie backs. That should be the final touches that I am doing on the interior. I have some damaged wood on the ceiling that I am still deciding if I want to mess with or not.
Posted: Mon Sep 21, 2026 12:35 pm
Getting down to the details.
New bedding from a dear friend of mine, a phone mount that won’t damage the dash and identification on the front nose for fun.
Posted: Mon Sep 21, 2026 8:21 pm
Yo! That plate is awesome!
Posted: Tue Sep 22, 2026 6:59 am
Here’s the website if you’re interested. They are very customizable. It was fun playing with it.
https://www.germanplateguy.com/?gad_sou ... POEALw_wcB
Posted: Mon Nov 02, 2026 8:45 am
by vwrick69
Awesome and incredible job Marla. It's great watching the transformation.
Posted: Mon Nov 02, 2026 1:28 pm
Thanks Rick!
Unfortunately, we will be doing this all again this winter. The transmission will need to go back for another round. I started this past weekend disconnecting the electrical, draining gear oil and gas. I got it up on stands and removed the rear wheels. I learned a few things last winter, so I am hoping to improve some things while the engine and transmission are out.
Here we go again!
