Kirk's........1960 Double Cab
Well, I started to move again on the DC.
The plan right now (a very loose one) is to replace some sheet metal and make it all one color again.
Along the way I would like to install some original safari windows.
What I need to do this winter:
1. cargo door lower
2. both front doors
3. both doglegs
4. right & left front floor sections
5. front nose (very bad inside and out)
6. safari windows
7. paint or primer Dove blue again
Re: CaptKirk........1960 Double Cab
Can't wait to see all the detailed pictures. This will likely be the 'great project of 2009'!
Are those cut up telephone poles in the back of you DC?
Yes, they make for great kindling/starter wood for the fireplace at home. :)
Randy
Post by Randy »
Looks like it is a great project. Is that the same truck you have had at RRR? Pretty sold to begin with.
1986 Westy
1974 Panel
Is that rubber bungee supposed to be holding the logs in case they fall? :lol:
21window wrote:Is that rubber bungee supposed to be holding the logs in case they fall? :lol:
Yes. Kirk is big on OSHA standards.
Just kiddding. Kirk really is big on safety. He wears eye and ear protection even when I'm talking to him.
Check out the pile of high $$ Gerson metal panels, they do look to be pretty good. I'll let you know how well they fit later.....
This is the guy making them http://www.klassicfab.com/marcos.htm
The only one stocking in the USA (not back ordered) is http://www.bustoration.com/Metal-Repair ... _c_11.html
Started with the cargo door:
Ended up with this:
Good stuff Kirk and very interesting. Looks like the panel fit very well. Keep us updated this is good learning material.
nice werk kirk...i put a gerson rocker and crossmember and outriggers on my single they all fit pretty nicely. your work looks great...I love that DBL
