Create an Avitar
Create an Avitar
How do I add thumb pic to left under username? (avitar)
2000 Rialta
1978 Beetle Convertible
Avitar
First you need a good picture.
Second you need to reduce it's size to 120x120 pixels and no larger than 6kb.
Third you need to log in to the site and upload the picture to your profile.
Once logged, upper right corner of screen click "User Control Panel"
Then left side of screen click on "Profile"
Same as above, click "Edit Avatar"
Middle of page click "Browse"
Find the image on your machine and "Submit"
If the image is the correct size it will upload great, if not you'll get a error message.
Don't worry if it takes a couple times to get it just right; it does me too
Re: Pictures
This site may make it easier to size your avatar.
http://www.shrinkpictures.com/create-avatar/
Re: Pictures
How to add pictures to your post.
1. Below the text box (you may need to scroll down a bit) you will see the
"attachments" tab. Click on it. Then click the add files button.
2. This will take you to your device's files ,my pictures on a windows device or documents.
3. Find the photo or document that you wish to add to your post. Click on it,then click the
"open" button.
4. Once the file has been loaded, you will see the "place in line" dialogue.You may need to
to scroll down a bit.Here you can also add a caption or comment to your photo
click on the place in line button and your photo will be placed.
"open" button.
