Page 1 of 1
I need a machinist
Posted: Sat Jul 20, 2013 11:01 am
by heyed67
eny body know someone who can line bore and thrust cut a case,crank balancing?????????
Re: I need a machinist
Posted: Sat Jul 20, 2013 11:25 am
Jim's custom VW in Columbiana for the case work. 800 621 3503.
CB performance for the crank.
http://www.cbperformance.com/ProductDet ... tCode=1105
This is cheaper than crank grinding AND it's counterwieghted and balanced AND standard bearing surfaces.
Although Jim should be able to set you up with a similar crank.
Also check with RIS for the case work
http://rismachine.tumblr.com/
He is a member of this forum.
Posted: Sat Jul 20, 2013 11:53 am
by WideFive
RIS can handle everything you need...
http://www.widefive.net/RIS2013
