camp fires
Locked
Vandiesel
camp fires
Post by Vandiesel »
I noticed on the camp map , there is designation for camp fire area.
are open fires allowed on individual camp sites? do we need to supply our own wood?
Re: camp fires
There are no ground fires allowed. You are allowed individual fires, but they must be in a fire pit (chiminea). There is limited wood so you may want to bring your own. No fire rings are supplied so you will have to bring your own.
Re: camp fires
I may add that there is a large fire ring at the beach for use as a group fire.
Re: camp fires
raised fire pits like the one pictured are permitted.
raised fire pit.JPG (89 KiB) Viewed 4235 times
Vandiesel
Re: camp fires
Post by Vandiesel »
ok , that kinda clears it up , I better bring both, a fire ring, and the raised pit.
Re: camp fires
Broaska wrote:ok , that kinda clears it up , I better bring both, a fire ring, and the raised pit.
I guess I should clear this up a bit. A fire ring would be considered a "ground fire" 4H's concern is destroying the grass in the areas where we camp.
Locked
