67 Beetle Turn Signals
Posted: Thu Oct 27, 2016 1:44 pm
Bad things happen in 3's? This might be #3 after Beetle parking lot hit and run, and Conetastrophe.
Initially the turn signal would not engage in the flash mode consistently, then not at all. Sometimes the lights would flash, but you couldn't tell from inside the vehicle. Then it got so the switch would not come out of flash mode. Now no turn signal lights at all. The switch is pretty loose on the column. Is it the relay- one of those 9 pin jobs, or the switch? I'm thinking the switch. I've ordered a new relay and will put it in. I'm guessing I'll still have no signals. How hard is it to get the correct switch and to do the replacement? Part # is partially obliterated on the top surface of the switch.
