Hans and Olaf
Posted: Tue Jul 14, 2009 12:33 pm
I work a little here and there for family friends, etc so I have a lot of free time to play with my parts and vehicles this summer.
I decided to pull the engine from Hans, 71 bug, last night to see how everything was doing. It's never been out in the six or seven years I've had him. Lucky thing I did, the upper drive side engine to transmission bolt wasn't there
Time to find one in my menagerie of stuff. Saw some surface rust starting where black paint was peeled, looks like steel brush and black paint will be on the to do list as well.
I'll probably also use him as a test bed to check out my spare engines since I can't seem to get a trashed transmission I have apart to make into a stand instead of a table like the other case I had. Anyway the bearing and plate/clutch look good so now it's time to wrestle a spare out of the barn to slip in. More than likely I'll start with the engine I was thinking of putting Webers on because I know it runs, at least a year and a half ago it did
As for Olaf, my mom's name for the 70 bus, I need to find a piece of stainless to turn on a lathe to replace the center sections of the engine lid hinges. I've heard the aftermarket hinges are bad from reading and a few volks here. Besides, it saves $$ and gives my dad and I some bonding time. Would anyone know the diameter of the pin, or what book to look in? I don't have calipers or a micrometer to check it out myself. Also, which would be better, tapping out with a hammer and nail/drill bit, or drilling out the old pin?
Then it will be time to figure out why the horn doesn't work. I hope it's just a bad horn and not bad wiring.
