1.7 Bus Core Motor $250
CB code, should be a 72/73 1.7 with dual carbs and an air pump. "Ran when parked" from a trusted source, but it was stored in a damp area and moisture got to it. Spins free but has 2 stuck exhaust valves, crank end play and fw vertical play are both slightly out of spec but not wasted. I was going to get it running and sell it but I think it's better suited for a core or builder, but you might be able to clean up the top end and get it running cheap if you're handy. It had air cleaners, carbs, throttle linkage, etc on it when I got it, they're all in a box included. Plug threads look good, no broken bolts as far as I got. Heads have the smog pump ports, you'll need to plug those for most applications.
