1965 Camper
Re: 1965 Camper
Post up the shag!
Re: 1965 Camper
That looks like a very restorable bus, about the same shape as mine when I got it. It should be a fun project!
Re: 1965 Camper
Looks like you have a some decent bones to work with. It's cool to see more of these non-Westy campers coming out of the woodwork. :D
sehilliard1
Re: 1965 Camper
Post by sehilliard1 »
Bruce- I've been a follower of your thread and am inspired by the work you did.
Kirk- unfortunately I was so turned off by the shag carpeting and so overwhelmed by the smell that I didn't stop to take pictures. I have it in garbage bags sitting outside the shop if you want to make me an offer on it!!!
sehilliard1
Re: 1965 Camper
A little elbow grease goes a LONG way. (all the way back to 1965!)
Image[/URL]Image[/URL]
Happy Turkey Day everyone!!
Re: 1965 Camper
Luckily it was probably rattle can with little or no real prep. What are you using to pull the paint off? I used to use Easy Off oven cleaner (in a spray can, not spray bottle) to remove lettering on trucks. It doesn't touch the base paint.
Looks great in the original paint, keep up the good work!
Re: 1965 Camper
Looking good Shawn
sehilliard1
Re: 1965 Camper
Bruce- I am using the EZ off oven cleaner to soften the primer it was certainly rattle canned on. Then I am following up with lacquer thinner to take the primer off and clean up. The few places that you can see in the photos where I burned through were caused by the oven cleaner I think. So I am only letting it sit on the primer long enough the soften it not take it completely off. Then working with the thinner and a terry cloth towel. I am pretty happy with the results. Below the belt line there is a coat of green paint that was put on with a brush it's a little harder than the primer and will take a lot more rubbing to get off.
sehilliard1
Re: 1965 Camper
Kirk: are you suggesting that my camper is a Riviera?
