1974 Transporter
Re: 1974 Transporter
Six Volt wrote:Awesome job! That's an amazing amount of work! I guess if you're going to do it you may as well be thorough! And you are being thorough!! :D
When you say the door skins and rear panels were "glued on", is that to keep them in place for welding? Or is that a substitute for welding? Just curious on how that works. What is the glue that is used? Can it be applied to painted/primed surfaces? or just bare metal?
Click here
Bustin' out LMGTFY....
Feisty.
1974 van
Post by 1974 van »
Glue should only be applied to bare metal. You glue then screw it on, taking the screws out after the glue dries.
when thru the complete brake system. Re upholstery the seats. That was a pain in the rear!
Original rear brakes?
Click here
Pretty amazing stuff.
1974 van
Post by 1974 van »
Painted. Now the fun part of remembering how stuff goes back together. I took it apart in 2010 :shock:
February 14th
February 14th
February 13th
February 13th
Painted Interior Jan 31st
Great job! Keep up the documentation!
Sweet :D . Things will fall right in to place now...no worry's.. :ugeek:
1974 van
Post by 1974 van »
Installed the front door windows last month with new trim. Had the rims blasted and painted. Finally got to put the engine back where it belongs!
March 11
March 11
March 11
March 11
February 24
February 24
1974 van
Post by 1974 van »
Headliners are fun :evil: Not!
headliner
headliner
headliner
headliner
Be glad it's not a split ;)
