My work's been busy so I've been working on the bus, but a lot of shorter days spaced in between work days.
I cleaned stuff up and resealed the steering box. Local bearing places did not have the seal in stock and wanted to charge me freight to get it in, so it was cheaper to buy it off of Ebay for $12 delivered. Strange how that works......
Box looks like new inside once cleaned up.
Cleaned the seal bore with a wire brush in a drill, it and the bushings look like new.
Cleaned the pitman shaft with 400 grit. There's still a slight line where the seal rides, but it will be fine on a manual box.
Tapped the seal in place with a seal driver and some High Tack.
The box cover does not get a gasket so I used High Tack like it's an engine case half.
Done, filled with oil, and ready for final clean, blast, and paint. It has a high spot in the center so I adjust it just like any other American box, (it's an ATE/Ross box!) to zero lash on the high spot. (pitman arm zero side play- no "click")
Left A Pillar with all of the bad stuff cut out. I also tented the bus again and sandblasted the areas to be welded.
Right A pillar with all of the bad stuff cut out, and the toe kick cut out.
Roughing in the right side "A" pillar metal.
That's the nose skin unfolded- it's not welded, it's CRIMPED onto the other piece all the way up!
Right side welded.
Left side, A pillar done, floor done, weatherstrip rail done. Not pretty, but functional.
I actually have the whole inner valance welded in and it went easier than I thought, but I didn't shoot full pics yet. The AC piece fit fukking perfect.
Next- right floor. The AC panel sure fits better than the black generic POS I used on the left side.
That should go quickly, then the lower front outer valance. Tip- buy the lower A pillar pieces unassembled. If they're assembled and welded (which a lot of suppliers do) you can't install them with the nose skin on. I got lucky by chance and got them unassembled.
