I finished welding and grinding the lower outer apron, it came out great.
The left seat belt mount was a bit funky looking, but it wasn't until I cleaned it well did I find it was pretty rotted. Here's an old pic zoomed in, I didn't shoot any closeups prior to cutting it out.
Here it is done, it came out great.
The PO must have lived on a dirt road because the rear crossmember was filled with dirt 2+ inches deep. I used the shop vac and an air gun to get it out as there is no real access to the inside besides the round hole where the heater tube runs through. Anyway, things didn't go so well. First, here's maybe 1/3 of the dirt that came out, second, it created a cloud like I've never seen by using a blowgun, third, I looked like an alien when I was done, and fourth, the fukking crossmember was done when I got done.
I used fiberglass jelly resin to seal up the welds around the wheelwells so water won't get in.
2 3/4" exhaust pipe fits perfect for replacing the rotted long heat tube, it's not easy to buy but Napa was able to get a 10' piece for $30.
Here is a small piece test fitted through the front crossmember and into the bent heater tube.
After sealing up the floors and bulkheads with FG, I mixed up some two part primer and shot the bottom. I'll continue working underneath doing a quick sandblast of the entire bottom and end up shooting gray acrylic paint on the whole underneath. I figure this is the best time, as once the outer body is done I sure won't want to be painting the bottom of the bus.
You might remember this front heater tube had a big rot hole in it, so I used glass mat and jelly to seal that up.
Next:
Replace the rear crossmember (ordered from ECC Tom), installing the heater tube at the same time so it won't have to be spliced. (est 4-6 hours)
Sandblast the bottom center section between the axles and paint it. (est 4-6 hours)
Reposition the bus on stands so the ass end is in the air higher, pull the trans, clean and paint the rear section. (est 6+ hours)
Chug, chug, chug. Just crossed 200 hours total, maybe 205 right now. Work is busy, slowing me down.
