Still cleaning underneath, it's dirty rotten filthy work that makes me envy Kirk's rotisserie. I figured I better do something with my heater cable tubes while I'm down there because the left one was broken off 2' from the tip.
I found the reason is because the other one is also plugged solid with rust, locking the heater cable in where it couldn't be removed from the control by the driver.
I tried the drill bit thing to clean the tube, it's plugged farther than the drill will go. I also tried the cable-in-the-drill thing, but there was no way in hell it was going to clear out.
I decided to cut the end off to find it clogged solid with rust. There was no way it was going to clean out.....
Which released the control allowing it to be removed.
I did ream both tubes with the drill cable, blew them out, and ran some brakeclean through them.
I used some 5/16" brake line to replace the 8mm tubing.
By chance 3/8" flare tube has exactly 5/16" ID which means it "sleeves" the tube perfectly for a splice.
Using a taper reamer removes the edge so the heater cable will slide through nicely.
I brazed the joints and tested them with a piece of heater cable which slides right through the splices.
Here they are done.
I also cable reamed the shift tube which had a bunch of yech in it.
The crossmember under the tranny was pushed in from a zillion floor jacks so I heated both lower edges and straightened them. I may reinforce this as it will likely see a few more jacks.....
Man, this is some filthy work, I have 12+ hours cleaning the bottom. If this is what the floor looks like after a couple of hours you know what I look like.
I've currently tarped the bus and am sandblasting the bottom. I like this cool weather we're having as it suits this perfectly.
