Page 8 of 33
Posted: Sun Dec 15, 2013 5:31 pm
by WideFive
Posted: Sun Dec 15, 2013 7:13 pm
by vw7266
the only person i would recommend doing final paint any body is Josh Hibbler at Rust Haven in PA
Posted: Tue Dec 17, 2013 11:42 am
by Busjunky
That really turned out nice!
Posted: Tue Mar 18, 2014 11:49 am
by Marla
I just thought I would give an update on Gunther...
I finally took the plunge and decided to upgrade his engine. I am having RIS build me a 1600 SP long block. Thanks to Mike R. I got off to a good start on parts. I dropped them off this past weekend. RIS will clean and inspect them to let me know what he can use. I am officialy in the queue.
In the meantime, I will be working on the brakes and getting ready for the spring. I am looking forward to getting him back on the road.
Posted: Tue Mar 18, 2014 2:32 pm
by TRL
Sweet!
Posted: Tue Mar 18, 2014 3:27 pm
macaia8475 wrote:I just thought I would give an update on Gunther...
Get this master cylinder. When you get it take it apart, hone it, clean it, inspect all parts and reassemble. PM me your address and I will get some assembly lube out to you. Throw new rubber parts on all the wheel cylinders while it is apart. I have part numbers for SS braided DOT approved lines made by a local company if you need those too.
Posted: Tue Mar 18, 2014 4:37 pm
by Mike Kever Kombi
If you go with the dual circuit, you will also need a reservoir
https://bustoration.3dcartstores.com/MA ... _1703.html
Is there a huge difference between the one Ronnie sells and the one you can get at Autozone?
http://www.autozone.com/autozone/parts/ ... 3_0_0_2867
Posted: Tue Mar 18, 2014 10:34 pm
Mike Kever Kombi wrote:If you go with the dual circuit, you will also need a reservoir
The AutoZone master is a bay part going off the picture. You might get the right part if the picture is just generic clipart.
Even if I purchased the supposed German master I would tear it down, hone, clean and inspect before I used it.
Posted: Wed Mar 19, 2014 12:01 pm
by Marla
Thanks for the heads up. I bought the dual master cylinder kit so it came with the resivoir, spacer etc...
Posted: Wed Mar 19, 2014 12:35 pm
Contact Greg (21 window) for synthetic brake fluid.
